3949tl | -- 10-07-2022 @ 9:01 AM |
Am having trouble trying to match up a starter with what I need for my 1940 coupe. It seems vague as to the year applications I am seeing on line from several different vendors. Do any of you know what year ranges I should be looking at? If seems that there are so many applications listed that would be a possibility but I can’t be sure. Would matching the shaft length and number of drive teeth be enough to put me in the “ ball park?” Thanks for any info.. I would also be receptive to acquiring a good used unit.
kubes40 | -- 10-07-2022 @ 9:37 AM |
For certain any '32 - '48 will fit and function perfectly. The exception? The 60HP starters. You can still get these at NAPA for a reasonable price, typically more reasonably than nearly every V8 parts vendor. Napa #: RAY 2449607, about $125, remanufactured. Mike "Kube" Kubarth
51504bat | -- 10-07-2022 @ 11:49 AM |
Starter for an automatic trans is different but no automatics in 1940. Only mention it in case the OP wants a used starter. ______________ No signature
3949tl | -- 10-07-2022 @ 3:18 PM |
Thanks for the response. Ordered one from Napa. Tom
37RAGTOPMAN | -- 10-12-2022 @ 7:07 AM |
REBUILT FORD STARTER, try CERTIFIED AUTO ELECTRIC, for a rebuilt ORIGINAL, DONE RIGHT, 440 439 1100 6vto12v@gmail.com I have used thier service and are real happy hope this helps 37Ragtopman
kubes40 | -- 10-12-2022 @ 7:24 AM |
At around $125, Napa is a bunch more reasonable. Plus, they are totally remanufactured to a very high degree of quality. Mike "Kube" Kubarth This message was edited by kubes40 on 10-12-22 @ 7:24 AM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=16009 |
