same | -- 09-06-2022 @ 7:51 AM |
on my '37 fordor i have lubed the chassis points and UV joint,and rear inner wheel bearing zerks at 800mi.-1kmi. i most generally drive car everyday about 10-15mi. ofcourse not in winter as i'm in iowa. how often do you folks remove wheels and re-grease outer wheel bearings? Tom.
51woodie | -- 09-08-2022 @ 5:07 AM |
One answer is in the post below, that was asked by Whitfield.
same | -- 09-08-2022 @ 6:59 AM |
hey 51woodie, my question was how often do you folks remove wheels and re grease outer wheel bearings,not what kind of grease to use. with all due respect i didn't see a response to my inquirey. Tom.
51woodie | -- 09-08-2022 @ 1:40 PM |
Tom. Sorry about that. I guess speed reading a technical question is not my best thing to do. I realize that you have a '37 Fordor, so the 1942-48 Ford shop manual indicates "clean and repack" at 10,000 miles. You referred to greasing the wheel bearing zerks. If these are the ones on the backside of the brake backing plates, there are members on here that suggest not to grease these, as it can cause grease to migrate on to the brake shoes. Have you pulled your rear hubs to service the bearings? Here is a video on packing the rear wheel bearings. https://www.bing.com/videos/search?q=1937+ford+rear+wheel+bearing&&view=detail&mid=58C74314E3AEC70901EA58C74314E3AEC70901EA&&FORM=VRDGAR&ru=%2Fvideos%2Fsearch%3Fq%3D1937%2520ford%2520rear%2520wheel%2520bearing%26qs%3Dn%26form%3DQBVR%26%3D%2525eManage%2520Your%2520Search%2520History%2525E%26sp%3D-1%26pq%3D1937%2520ford%2520rear%2520wheel%2520bearing%26sc%3D1-28%26sk%3D%26cvid%3D1D05103E06C1461AA8C9403C458DA57B%26ghsh%3D0%26ghacc%3D0%26ghpl%3D
51woodie | -- 09-08-2022 @ 1:44 PM |
Looks like the length of the link cut off some of the info. Ford recommends 10,000 miles for bearing service.
same | -- 09-09-2022 @ 6:29 AM |
thanks,51woodie,Tom.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=15933 |
