MOXIE | -- 07-23-2010 @ 8:36 PM |
Anyone ever use one of the cut to length to fit drive shafts that speedway has. They are suppose to be a replacement shaft for a 34. You just cut to length and weld the female spline in. I called speedway and they said the diameter of the tubing is 1 3/4" and the tubing is a little over a 1/16" thick. Does not sound like a very strong shaft.
JM | -- 07-24-2010 @ 6:13 AM |
That driveshaft is made by Dick Spadaro. You could contact him to discuss your concerns. Sorry I mentioned the above to you Moxie. Will know better than to respond to your posts in the future. J.M. This message was edited by JM on 7-26-10 @ 8:56 AM
MOXIE | -- 07-24-2010 @ 7:28 AM |
I would like to hear from someone who has used the shaft. Not someone who sells it.
supereal | -- 07-24-2010 @ 7:41 AM |
There is more to welding a driveshaft than just laying it down and sticking it together. Any slight deviation from straight will result in an annoying periodic vibration. We use a long bed lathe as a jig for that job.
37RAGTOPMAN | -- 07-25-2010 @ 8:16 AM |
Moxie. what are you trying to acomplish,SPECIAL APPLICATION? I am thinking, maybe you should go to a drive shaft shop and see what they say, 1/16 thick is just a little to thin for the job, if we know what you wanted to do it might be a little easier to figure out, hope this helps 37 RAGTOPMAN KEEP ON TRUCKIN,
supereal | -- 07-26-2010 @ 10:03 AM |
The hollow drive shafts are very strong, and made of special material. This requires a special welding technique to preserve the temper.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=1593 |
