Scruffy | -- 09-01-2022 @ 11:54 AM |
Where is the circuit breaker on a 1939 deluxe sedan?
MG | -- 09-01-2022 @ 12:23 PM |
Mounted on the firewall under the dash. It's next to the ignition resistor... See > https://www.ebay.com/itm/174889726590?hash=item28b83d727e:g:PTMAAOSwHAZhaCLM&amdata=enc%3AAQAHAAAAsG2E%2B3AU%2FffY1KlvFOPZW2ap9VSWq8plvrUKPmpAL4wRIKNjfdZowlty%2B%2FkprZKVucFaEmmppkGTEBgJuRX%2BZk1%2B4fGKxajQL5zBBAxCUTg2600u9LPwQclVL7rbkSmrGZ8hqUwoeI9kSoCNI%2BPp1HF%2FfWZ9FMuZOtE0doa%2FYA3bG8t7rcRBodEQmBexWm09zIqdPcqS7%2BpJni0eKlAI8hBOk6%2FjqZKdndqRnm8QhyQZ%7Ctkp%3ABk9SR77MgajfYA
ford38v8 | -- 09-01-2022 @ 12:29 PM |
The '39 DeLuxe employed a smallish circuit breaker, without air holes as did the later and larger circuit breakers. It is located on a fiber fuse block next to the ignition resistor, directly above the steering column inside the dash panel. It is a bit awkward to get to, but not inaccessible. The '39 Standard Ford still used a 20 amp fuse mounted on a slightly smaller fuse block in the same location. Alan
ford38v8 | -- 09-01-2022 @ 12:43 PM |
Note that the epay item shown in MG's post is not correct for a '39 Ford. The correct part number is 91A-12250. Alan
40 Coupe | -- 09-02-2022 @ 5:07 AM |
Note the link above does not show the 39 circuit breaker but the location is correct.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=15920 |
