SKnapp | -- 07-23-2022 @ 6:18 AM |
I have a '39 Woodie that was passed on to me by my father; unfortunately neither his knowledge nor diagnostic skills came along with it. It's recently started making noise when I'm driving and let off the gas - basically when the driveline is unloaded. Sort of a whining / howling noise which is higher pitched at higher speeds. If I step back on the gas or put it into neutral the sound goes away immediately. It does have a Columbia, and the issue is the same whether the Columbia is engaged or not. Any suggestions about what might be leading to this are greatly appreciated!
carcrazy | -- 07-23-2022 @ 9:11 AM |
One source of this whining on decelerations could be wear on the ring and pinion. When you have the rear axle under a load, the pinion is driving the ring gear and it is silent. When you take the load off of the axle, the ring gear drives the pinion and the wear allows the alignment between the two gears to change producing this noise.
ford38v8 | -- 07-23-2022 @ 11:57 AM |
Back in the day, used car dealers employed “auto detailers” whose job it was to do such things as set odometers back and put sawdust in growling differentials. Of course, nowadays, they wouldn’t think of stooping to dishonest means to sell a car, would they? Alan
CharlieStephens | -- 07-23-2022 @ 12:19 PM |
Two suggestions. Put your general location in your profile and maybe someone will offer to come by and help. Check out local clubs in your area: https://www.earlyfordv8.org/Regional_Club_Directory.cfm Charlie Stephens
37RAGTOPMAN | -- 07-23-2022 @ 3:03 PM |
first thing you want to do is drain the rear , in a clean pan and run a magnet though it and to see if there is any metal particles this would be the easiest way to see if there is a problem in the rear end, also the trans oil could be drained and check that also, hope this helps 37Ragtopman maybe fresh 140 weight gear oil might help
MG | -- 07-23-2022 @ 3:20 PM |
Maybe the Columbia doesn't have any gear oil in it...
SKnapp | -- 07-24-2022 @ 7:05 AM |
Thanks for the suggestions! I had the rear end drained and the fluid replaced, and the mechanic didn't mention anything. The ring and pinion explanation seems to match what I'm hearing pretty closely. I'm in the San Francisco Bay Area (East Bay.) It looks like there are several regional groups close by for me to check out. Steve Knapp This message was edited by SKnapp on 7-24-22 @ 7:06 AM
CaliforniaBorn36 | -- 07-26-2022 @ 4:24 PM |
Steve, where do you live in the East Bay. I am in San Leandro and belong to the Golden Gate Charter Region Group #1. We meet in Hayward. I tried to PM you, but you appear to have that disabled. I might have some suggestions for you. Go ahead and PM me if you are interested. Matt Beall
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=15825 |
