fe427t | -- 07-20-2010 @ 8:59 PM |
Who makes the best wiring that fits? thanks
37don | -- 07-21-2010 @ 4:54 AM |
I use Rhode Island Wire in West Kingston R.I. Phone # 401-789-1955.There work is second to none and they will work with you on any mods you might like make to harness.I did our 37 sdn and incorperated turn signals and elect pump wire and left and right temp wires for future use all in the same harness. Good luck, Don This message was edited by 37don on 7-21-10 @ 4:59 AM
supereal | -- 07-21-2010 @ 9:46 AM |
Almost all replacement harnesses contain circuits that are not the same as the original. Before you buy, it is a good idea to inquire about that possibility, and request a diagram of the new harness. To save time, many fabricators make harnesses for several models of the same make, model, and year that will span the differences., but cause problems as you install it.
37don | -- 07-21-2010 @ 11:40 AM |
Hi Supereal, these people make their harneses as exact duplicats of factory harneses. They fit perfectly using the Ford diagrams. If you want to add wires they will do so and give you a detailed diagram for the added wires.They do just about any car or truck that you can find including most foreign cars and ship all over the world.They just plain do it right. By the way Supereal, I read all of your posts and find them to be very helpful. Don
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=1582 |
