Topic: 36 ford
chucky    -- 07-06-2022 @ 1:58 PM
  Finally got my 36 on the road. Can't seem to get it over 40 mph floored. Any thoughts. Thanks
carcrazy    -- 07-06-2022 @ 8:16 PM
  Check the following:
Air cleaner for blockages caused by rodents, wasps or other vermin
Exhaust system and muffler for the same
Make sure the fuel tank is properly vented
Check the fuel pump for proper amount of fuel delivery
chucky    -- 07-07-2022 @ 5:54 AM
  thanks, I will check those items
37RAGTOPMAN    -- 07-07-2022 @ 6:51 AM
  36 FORD
with engine off, check for FULL THROTTLE, make sure you have the correct throttle rod,
and the rod from gas pedal to the limkage, something might be a obstruction or bent
also check which carburetor you are using, should be a 48
years ago a friend had a similar problem., he had installed a 60 horse power carburetor
I found the problem,
I think carcrazy had a few good points to check out,
hope this helps, 37Ragtopman
chucky    -- 07-08-2022 @ 11:05 AM
  Thanks for the help
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=15789
