ibshane | -- 06-27-2022 @ 11:51 PM |
Does anyone offer some kind of add-on spring for '37-39 style wiper arms? I need to somehow increase the tension on mine.
51woodie | -- 06-28-2022 @ 6:40 AM |
I can't offer an answer, but I can give you an opinion assuming you have vacuum operated wipers. The wipers on my '46 Coupe were very slow, and sometimes hung up until I played with the throttle to get them moving again. What I found was, a previous owner had installed non stock wiper arms and blades, that were heavy and had higher spring tension that the original design. The wipers worked a lot better after installing the proper pieces. RainX also helps. Moral of the story, higher spring tension may cause the same problem I had.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=15766 |
