Topic: 6 volt coils
BoogityBob    -- 06-21-2022 @ 3:32 PM
  Looking to replace my coil. how many ohms should my coil be rated for? 1949 Ford V8 6 volt pos ground. Thanks
JayChicago    -- 06-22-2022 @ 9:57 AM
  6 volt ignition should have about 1.5 ohm total resistance, to get about 4 amps running thru the coil and points.
I believe no ignition resistor was used 1949 and later, it’s all in the coil on your car. If I am correct, no resistor used, get a 1.5 ohm coil.
BoogityBob    -- 06-22-2022 @ 12:27 PM
  thankyou Jay
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=15752
