Topic: BATTERY DISCONNECT DEVISE
wrech ranch    -- 06-21-2022 @ 6:29 AM
  Many of us utilize the disconnect device which employs a plastic knob on top to loosen for disconnect. (Usually a green knob but some are black) I have found that occasionally the knob post will become corroded and prevent good contact.
Simply scr*pping the corrosion is a fix but cleaning and applying a little dielectric grease is longer term.
greg childs
Wrench Ranch Montana
37RAGTOPMAN    -- 06-21-2022 @ 12:17 PM
  mine was brand new and they are junk from the get go
if you want a disconnect switch that works you will need a MASTER FLIP SWITCH, around $30.00
but hard to mount on a 37,
I have one on my MODEL A for 40 plus years with no problems,. mounted to the floor between the front sets,
my 2 cents 37Ragtopman
but if you have one good luck and if you have any problems you will know were to look first .
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=15750
