Early46 | -- 03-26-2022 @ 5:28 PM |
It's been a while since I posted, life...... Anyway, does anyone have any tricks or ideas for installation of the E-Brake/Speedometer grommet in the firewall. The one that came out of this car (46 tudor) looks to have been cut to fit over the cables and then installed. Looks like this is going to be a pain! Thanks!
carcrazy | -- 03-26-2022 @ 10:20 PM |
Yes, cut the grommet to enable an easy installation. After it has been installed, you can use superglue to join the cut ends back together and locate the cut area so it will not be readily visible.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=15564 |
