chris46 | -- 02-10-2022 @ 7:43 AM |
If you have installed vintage style 6V switch with a lite on the end of the lever and it glows when the switch is off and only glows when you move the lever up or down , you cant use the #535 flasher that comes with the kit. You can use a 229d flasher ,these are out there ,[ebay] I found this out when installing a kit on my 1946 ford.
dean333 | -- 02-11-2022 @ 6:51 PM |
Reread your post. First you say it only glows when off then you say it glows when up or down. Which is it?? TIM CARLIG
37RAGTOPMAN | -- 02-13-2022 @ 6:35 AM |
turn signals does the signals work ??? you never said, or is the stem just glowing,? does the stem light blink, with the flashers on ??? when making a turn did you try another flasher unit, seems to me that it might be stuck, broken inside ~!! recheck the how it is wired, does the flasher plug in, ? I would also check ALL THE BULBS, in the sockets and make sure you have the CORRECT BULB'S there might be a back feed, someone might have installed a wrong bulb ? is this car new to you ? much more info it needed, to figure out what your problem is, hope this helps, 37Ragtopman This message was edited by 37RAGTOPMAN on 2-13-22 @ 6:39 AM
1931 Flamingo | -- 02-13-2022 @ 8:24 AM |
Somewhere I just read a person solved this problem by replacing flasher with a different kind. Paul in CT
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=15480 |
