35gal | -- 07-13-2010 @ 4:10 PM |
Can a 1936 car drive shaft be modified for a 6 spline pinion. I know you will need an adapter from 10 to 6 but the existing 10 spline end of the shaft seems to hard steel to bore for the adapter.
RSS | -- 07-13-2010 @ 4:26 PM |
Yes, the drive shaft can be modified. I had my 1935 (tubular style) drive shaft modified by a local drive line shop. they removed the 10 spline bung, took a 6x10 spline adapter (that I supplied) cut the 10 spline side off, machined the 6 spine bung to fit the drive shaft, and welded it in place
supereal | -- 07-13-2010 @ 4:51 PM |
That isn't a hard (no pun intended) job, but should be done in a long bed lathe and welded by spotting a few places before finishing the rest. This keeps the shaft from warping from the heat as the piece is turned. Any slight off center will create a vibration.
35ford | -- 07-14-2010 @ 5:47 PM |
I have had a drive shaft shortened and a 35 modified and would only have it done by a speciality drive shaft shop. jmho
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=1547 |
