chuckwp | -- 01-12-2022 @ 2:31 AM |
Need assistance installing front and rear side windows in a 1935 Ford Tudor. I did not disassemble the car so, I need a little advice on going back together. It is not my car, but am working on it for a customer. The window glass is not installed in the lift/sash channels. I am not sure of the correct positioning of the lift channel on the glass and understand that if not correctly, the window will not work. I am thinking it should be centered on the glass but, with no reference am not sure. I have done searches on the net but, have not found an answer. So, if anyone has pics or, a procedure, it would be very helpful.
JM | -- 01-12-2022 @ 8:30 AM |
If you haven't tried searching in the archive files of www.Fordbarn.com , I would suggest you give that a try for the information you are seeking. You may need to become a member there to use the search function....not sure on that. I do know there have been previous posts there on this same subject that discussed location of lower window channels on glass, and instructions given on installing side window and door glass. John This message was edited by JM on 1-12-22 @ 8:31 AM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=15421 |
