kirkstad | -- 01-05-2022 @ 1:38 PM |
I have installed a 6volt optima battery in my stock 36. I'm not sure, but I believe someone mentioned on the forum awhile back, that you shouldn't use a battery tender on this type of battery. I want to maintain it during these winter months. Thank you. Frank.
Jacques1960 | -- 01-05-2022 @ 3:37 PM |
A NOCO Genius is ideal for a 6v AGM (or any other battery for that matter). I use for both my 36 Phaeton and 38 woodie, both with Optimas
ford38v8 | -- 01-05-2022 @ 4:54 PM |
From the website, it looks like the Noco Genius 10 is the one for 6v Optima. I have an old, never used, Optima of the shorter version that is completely dead. This charger sounds like it may revive that battery! I think it's worth a try, any other opinions? Alan
kirkstad | -- 01-06-2022 @ 11:53 AM |
Thank you guys, I'll see if I can find one. Frank
kubes40 | -- 01-06-2022 @ 12:51 PM |
Alan, I have never been able to revive an Optima. However, I believe it's always worth a try. Not much to lose by trying. Mike "Kube" Kubarth
kirkstad | -- 01-06-2022 @ 1:13 PM |
My optima is only a year old and is fine, I just want to keep it up to par when not in use during the winter. perhaps I should remove it from my car and keep in in the house. My garage is not heated and gets pretty cold during the winter months. The Noco genius charger, that Jacques1960 mentioned, is out of stock right now. Thanks. Frank
ford38v8 | -- 01-06-2022 @ 4:14 PM |
kirkstad, One of the advantages of the Optima battery is that it doesn't self discharge. A seasonal storage should retain its charge till driving season again. It is advised, however, that for that storage period, you at least disconnect the battery cables. Alan
kirkstad | -- 01-06-2022 @ 4:49 PM |
Thank you for that information Alan. Frank
TomO | -- 01-07-2022 @ 8:38 AM |
The Battery Tender Plus is recommended for AGM batteries. I have been using the Battery Tender and the Battery Tender Junior to maintain my Optima batteries since 2014. Tom
kirkstad | -- 01-07-2022 @ 12:01 PM |
Thank you Tom, I appreciate your response and the information. Frank
fenbach | -- 01-07-2022 @ 9:51 PM |
frank scheidt wrote an article in 2018 about how to charge a dead optima. i think you put a traditional battery in series with the dead one and the charger. i don't remember where the article appeared, but likely the V8Times, maybe the foundation newsletter.
Robert/Texas | -- 01-08-2022 @ 9:03 AM |
Early last spring, I accidently shorted out an almost new 6-volt Optima battery in my Model A. I tried to charge it with my multi voltage battery charger. It gave me an error code and would not charge it. I checked it with my voltmeter, and it showed a little over one volt. I charged up a 6-volt wet cell battery until it was fully charged and then hooked the two batteries together with jumper cables for about a half hour. Then I connected the charger and then left both batteries together until the charger indicated that they were both fully charged. The Optima battery is still working in my Model A and cranks the engine a bit faster than the wet cell battery did.
ford38v8 | -- 01-08-2022 @ 11:44 AM |
Good info, gives me hope on reviving mine. About hooking a good battery to a dead one to charge, the Noco 10 has an overide button to allow a charge to begin. I’m gonna buy one, give it a try. Alan
TomO | -- 01-09-2022 @ 8:54 AM |
The current "smart" chargers won't charge a battery that has less than 1.5V per cell (4.5v for a 6 V battery, 9V for a 12v battery). If you have an old fashioned "dumb" charger, it will charge the battery if it is not damaged or worn out. Connecting another battery in series with your "dead battery" will provide the voltage that the smart charger needs to recognize that it is connected to a battery and to start charging. Alan, you can try charging your Optima with Noco charger, but I doubt that it will take a charge after being dead for a long time. The plates have probably sulfated or been damaged by being discharged fro so long. If you don't need a charger, I would just take the battery to a battery store like Batteries Plus nad have them try to charge your Optima. They have chargers that will try to recover a sulfated battery and the store near me doesn't charg you if they cannot charge the battery. Tom
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=15410 |
