jal9846 | -- 12-28-2021 @ 5:38 PM |
Can anyone tell me the proper torque specs for a V8-60 Cylinder heads (cast iron) and intake (aluminum)? Working on a 1940 60-hp....and needing the correct specs. Thank You!
Dave239 | -- 12-28-2021 @ 6:22 PM |
50 ft lbs for iron heads 30 ft lbs for aluminumumum heads If your are using after market heads and intake use the manufacturers recommendation for torque Dave This message was edited by Dave239 on 12-28-21 @ 6:27 PM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=15388 |
