dragnil@sbcglobal.net | -- 12-04-2021 @ 12:46 PM |
I have a 1936 ford 5 window coupe deluxe ,I think it has a tag model 68-770 can you identifie it ? Roy Lingard dragnil@sbcglobal.net
nelsb01 | -- 12-04-2021 @ 3:32 PM |
68 is 1936 V-8 770 is 5 window body style You can find other information from the menu to the left Click on Ford Information and in the displayed menu then click on Car Codes From the pull down menu find Ford 1936 Hope this helps. Please note that this information is not your vehicle VIN . That is located on the top of the frame rail, drivers side, near the steering box mount. It will start with a stamped 'star' followed by 18 - xxxxxxxxx and end with stamped 'star' You may have to use steel wool to clean up the area -- do not use too harsh a cleaner as the numbers were not stamped that deep into the frame rail. This message was edited by nelsb01 on 12-4-21 @ 3:33 PM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=15332 |
