deskjet894 | -- 11-10-2021 @ 3:21 PM |
Can you identify this radiator? Thank you in advance!
pauls39coupe | -- 11-10-2021 @ 4:35 PM |
Looks like it nay be a 1939, split core, with crank hole.
TomO | -- 11-10-2021 @ 5:17 PM |
The tall upper tank and the filler in the center of the radiator, makes me think that it is a 1941 radiator. I believe that it is an aftermarket radiator because it does not have the identifying stamp on the top tank. Tom
kubes40 | -- 11-10-2021 @ 5:26 PM |
Paul, not even close to a 39 ... Mike "Kube" Kubarth
joe b | -- 11-11-2021 @ 6:07 AM |
It looks like a 1941, Same as my 1941
sarahcecelia | -- 11-11-2021 @ 7:39 AM |
Looks like the same one in my 1940; Split core with hole at the bottom for the hand crank. But mine has the filler and cap on the driver's side; so 1941? Regards, Steve Lee This message was edited by sarahcecelia on 11-11-21 @ 7:41 AM
kubes40 | -- 11-11-2021 @ 2:08 PM |
Huh? Looks the same but different? ??? Mike "Kube" Kubarth
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=15279 |
