Bazooka Joe | -- 11-10-2021 @ 12:05 PM |
Looking to ID radiators, I believe the brass one is from a 1942 Ford, has these numbers 21A then under that G. and manufactured in Green Island NY Ford radiator factory. Not sure about the other radiator? The black painted brass, has 1.25” diameter top hose connections, and says IBA-D under that says GI . The brass one leaks and brackets on both are cut and partially missing, anyone know the value as is. Seems both are all brass except for the brackets. Thank you Joe
TomO | -- 11-10-2021 @ 5:45 PM |
The 21A radiator is for a 1942 Ford or Mercury. The 1BA radiator is for a 1951 Ford. I don't know how much any one would pay for either of the radiators. They are both donor radiators as the cores appear to have excessive fin damage and the brackets are damaged. Tom
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=15277 |
