Peter in NH | -- 11-09-2021 @ 7:19 AM |
My 35 Convertible Sedan has the type door hinge pins with an annular groove on the shaft. When permanently installing should I take the time to put a small amount of white grease in the slot of each pin before I drive them in? Peter
3w2 | -- 11-10-2021 @ 11:36 AM |
Better yet, a light film of white grease on both on the pin and in the openings of the female portion of the hinge.
Peter in NH | -- 11-10-2021 @ 4:50 PM |
3w2 Thank you for your suggestion of lightly greasing both the male and female surfaces. It certainly makes sense to do so. Peter
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=15274 |
