Savvy | -- 07-08-2010 @ 8:11 PM |
I'm going to put in new interior into my '34 Fordor soon. Does Acostishield insulation make that big of a difference? Anybody use/install it? Is it as easy as Mac and LB say it is to install? Cheers!
TomO | -- 07-09-2010 @ 7:56 AM |
I have not used Mac's kit but I did install acoustic material in my doors and quarter panels as well as a heat shield material under my carpet. It has reduced road noise considerably. You need a smooth surface to attach the material to, any roughness will reduce the bond strength. Tom
trjford8 | -- 07-09-2010 @ 8:17 PM |
Make sure that any material you use as a sound deadner will not absorb water.
bo8109b | -- 07-10-2010 @ 1:53 PM |
Would hesitate to use any sound deadener that needs to be glued to the sheet metal. Have you ever tried to remove glued down foam back carpeting?
shogun1940 | -- 07-10-2010 @ 6:08 PM |
i just bought dyna mat for the first time . best price on the net was from streetsider $119.00 for enough to do the car
1934 Ford | -- 07-14-2010 @ 6:45 PM |
I'm not familiar with the name brand Acostishield insulation, but I have 34 Fordor that I did the interior in the "leatherette" about 5 years ago. First: I got in the empty car with a 4" grinder with a wire cup and cleaned the entire inside of the body and doors. Second: I painted the entire inside with Hammerite rust prevention paint. Third: The entire inside of the body was lined with that two sided aluminum stuff with the bubble pack inside. I used spray 3M Adhesive to attach it to the hammerite painted surface. I even did the floors. Fourth: All the hardware was re-installed Fifth: Put the new interior in. This is the fourth 34 Ford that I've done this to and I'm still happy with it for these reasons. #1 It's real quiet #2 It's waterproof (And I drive rain or shine) #3 It gives the doors a real quality sound when closing. #4 Very light weight. #5 I did it myself (And it's invisable, with few places needing a touch of paint) #6. Maybe most important for a dark blue Florida car is that it does not transfer the exterior heat to the inside. (What a cool ride) This message was edited by 1934 Ford on 7-14-10 @ 6:47 PM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=1525 |
