jretter | -- 10-16-2021 @ 10:23 AM |
Does anyone know if I can replace the 6V Sparton horn motors in my '34 horns with later model 12V motors? For example, will the guts from a '62 Ford Fairlane (or some other 12V car) be adapted into a '34 horn so that they still look like '34 horns? That would be a slick way to switch to newer 12V negative ground horns. What do they use for the motors in the reproduction 12V '34 horns that Mac's and C.W. Moss sell?
37RAGTOPMAN | -- 10-17-2021 @ 1:06 PM |
did you try to use a voltage reducer 12 v to 6 volt ? to see if that works ? might be the easier way to go. hope this helps, 37 Ragtopman
Robert/Texas | -- 10-25-2021 @ 6:56 AM |
I didn't do anything to the horns in my '34 roadster when I converted to 12 volts/negative ground over 20 years ago. The only problem is that they are really loud. I seldom use them but when I do I just tap the horn button for an instant.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=15220 |
