mzahorik | -- 10-06-2021 @ 11:34 AM |
When I drive my 1937 in a straight line, the steering wheel is maybe 30 degrees clockwise of what should be straight. The steering wheel is keyed and can not be rotated. Could I have the pitman arm off by a little? How else can the wheel we centered. One of the wheel's arms covers the gauges while going straight. Thanks Mike
mzahorik | -- 10-06-2021 @ 11:40 AM |
After looking a little closer, it appears that if the drag link is adjusted the steering wheel will change. Is this the correct way to adjust for center? Thanks Mike
mzahorik | -- 10-06-2021 @ 1:48 PM |
Well.... I shortened the drag link two full turns and this straightened the sterring wheel. THanks, Mike
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=15197 |
