silverchief | -- 09-26-2021 @ 10:24 AM |
On my 49 pickup, the oil pan drain bolt is centered in a "clean out plate" fastened to the pan with eight 5/16. 24. bolts. It has been leaking so I removed the plate to clean it and install a new gasket. Does anyone know if Ford has directed a a specific torque for these bolts, or where I might find that information? Thanks.
alanwoodieman | -- 09-26-2021 @ 10:32 AM |
just use a torque table for the size of bolt--be sure to use an adhesive sealer on the ring of bolts/nuts and gasket on the pan-they are notorious leakers
silverchief | -- 09-27-2021 @ 8:01 AM |
Thanks very much Alan. I have a new gasket and a new tube of Permatex. I'm happy to know they have a rep for leaking.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=15177 |
