bw3240 | -- 08-26-2021 @ 10:01 PM |
I need the paint codes for the two colors on 40 DeLuxe dashboards. Thanks for your help.
trjford8 | -- 08-27-2021 @ 4:34 AM |
Drake has or maybe had the correct colors in spray cans.
kubes40 | -- 08-27-2021 @ 9:04 AM |
Drake had colors for the dash that well, were supposed to be for the dash. Correct? Laughable unless of course the formulas were changed. I recall the gold tone having a very distinctive pink to it. His maroon was fairly close - I'll give him that. I probably have current codes for the dash. PM me if you have not obtained them yet. I'll need your email. Mike "Kube" Kubarth This message was edited by kubes40 on 8-27-21 @ 9:06 AM
RAK402 | -- 09-01-2021 @ 9:44 AM |
Kubes40, I would like the correct paint codes too sir. When I had my car painted in 1976, the two colors I was given as correct were "Monaida Maroon" and "Copper Sand Metallic." I think Monaida Maroon was correct, but now I see "Rose Sand Metallic" as the correct second color. The restored '40 Deluxes I have seen all have a much greater metallic content in the Rose Sand color-I don't know what is correct.
kubes40 | -- 09-02-2021 @ 6:16 PM |
Guys, I'll do my best to have them sometime tomorrow (Friday). Sorry for the delay. Mike "Kube" Kubarth
bw3240 | -- 09-02-2021 @ 7:39 PM |
Thanks Mike, let us know when you have the time
RAK402 | -- 09-02-2021 @ 11:08 PM |
Thank you sir!
kubes40 | -- 09-03-2021 @ 7:15 AM |
Guys, sorry for being so tardy fulfilling this request. I am unable to get my scanner working at this time so bear with me... I'll type each code up in a separate post. Mike "Kube" Kubarth
kubes40 | -- 09-03-2021 @ 7:40 AM |
"GOLD" PAINT CODE: CHROMOBASE The Axalta (formally DuPont) formula code is: B8412K, Light Sandstone, Code #7789. If you go to a paint supplier that can mix this for you, the formula will come up in their system. NOTE (this is important) reduce the #814J, Coarse Aluminum by 50%. All of the other tints remain as specified in the formula. So, here's exactly what you want to mix (pint): #814J, coarse aluminum, 27.0 (this is the reduced amount) #802J, LS White, 77.3 #811J, Medium Aluminum, 86.6 #806J, HS Black, 95.4 #891J, Transox Red, 100.9 #858J, Deep Maroon, 103.1 #150K, B/C Balancer, 395.9 #175K, Binder, 433.7 "MAROON" PAINT CODE: CHOMOBASE The Axalta (formally DuPont) formula code is: 020173K. If you go to a paint supplier that can mix this for you, the formula will come up in their system. So, here's exactly what you want to mix (quart): #884J, LS Red Oxide, 87.3 #805J, Jet Black, 250.8 #864J, Magenta, 302.0 #886J, Opaque Red, 343.7 #829J, Light Blue, 368.4 #150K, B/C Balancer, 854.6 #175K, Binder, 874.6 Mike "Kube" Kubarth
RAK402 | -- 09-03-2021 @ 6:21 PM |
Thank you sir!
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=15108 |
