johnsa | -- 07-05-2010 @ 9:43 PM |
I'm trying to build a 40-50's period correct hot rod, did they fill the roofs in those days or leave the soft tops in? Thanks!
trjford8 | -- 07-06-2010 @ 6:54 AM |
You probably need to look around for some old hotrod magazines. Here's a couple of websites to check; www.AHRF.com and www.jalopyjournal.com. Both should have lots of info on period hotrods.
supereal | -- 07-06-2010 @ 8:45 AM |
The way we did it was to obtain a roof panel from the salvage yard, usually from a sedan, and trim a piece carefully to fit the opening. This provides some contour, rather than just a flat piece. It takes a lot of time, but will result in a neat conversion if done correctly.
CharlieStephens | -- 07-06-2010 @ 2:01 PM |
You might try posting on HAMB, http://www.jalopyjournal.com/forum/. They are more into the non-original changes. Ask which vehicle is best for a doner car. Be sure to include which body style and year of vehicle you have. Street rod vendors have roof inserts for some models. Charlie Stephens
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=1506 |
