40fordor | -- 07-05-2010 @ 5:33 PM |
When the emergency (parking brake) is fully engaged it activates the brake lights. I can see the foot brake petal move down just a little when at the same time. What adjustments do I need to examine to correct this problem? I have been throwing the battery disconnect switch to avoid battery discharge. Don
trjford8 | -- 07-05-2010 @ 7:35 PM |
The switch has slotted holes for the screws and should be adjustable.
MOXIE | -- 07-05-2010 @ 8:09 PM |
The brake pedal needs to have a return spring to keep it in the upright position when emergency is used. This is a seperate spring than the one that controls the brake equilzer unit.
40 Coupe | -- 07-06-2010 @ 9:12 AM |
the clevis at the brake cross shaft 48-2466 has an elongated hole for the pin, so the cross shaft can move without moving the brake pedal.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=1505 |
