4ford | -- 07-31-2021 @ 9:23 AM |
1941 ford horn button.. can you utilize this button and use 12 volts if so what would the wiring look like? thanks
alanwoodieman | -- 07-31-2021 @ 9:49 AM |
horn button's only ground a relay to activate the horn, they could care less about voltage. but the relay must be for the voltage you are using
4ford | -- 07-31-2021 @ 9:56 AM |
thank you is there anyone that has a picture of how it looks under the horn button i have nothing to go buy or some where i could look?
4ford | -- 08-04-2021 @ 6:47 AM |
No one has a horn button assembly picture?
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=15035 |
