poss | -- 07-04-2010 @ 5:45 AM |
is the brake light wiring harness part of the headlight harness? or seperate.
trjford8 | -- 07-04-2010 @ 7:23 AM |
The brake light wires are part of the headlight harness.
Don Rogers | -- 07-04-2010 @ 8:43 PM |
The brake light harness is separate from the headlight harness and carries part # 68-14405. The headlight harness carries part # 48-11647.
37RAGTOPMAN | -- 07-05-2010 @ 6:11 AM |
as far as I can remember,the fuel gauge, park lights,stop lights are in one loom going to the back,they connect in the front by the switch at the bottom of steering column,and fire wall,and at the stop light switch, if you buy your wires from RHODE ISLAND wiring you will receive FULL INSTRUCTIONS, hope this help,37RAGTOPMAN KEEP ON TRUCKIN,,,, are you a club member,? if not join,you will gain much knowledge....and HAVE FUN,,,,!!!!!!!
trjford8 | -- 07-05-2010 @ 7:28 AM |
Don, all the wires for lighting, including the brake light wires terminate at the bakelite block in the light switch. Is the tailamp/stop lamp wire harness separate from the front lighting? In dealing with repo harnesses I have found that they are all one harness. Is there a difference between the repo and original?
supereal | -- 07-05-2010 @ 10:54 AM |
My '36 wiring diagram shows that the brake lights are powered by a green wire attached to the input of the lighting switch on the column where the yellow-red wire feeds the switch. The green wire goes on to the brake light switch, then on, as a green wire, to the brake (stop) lights. The system can be changed to feed the brake light circuit from any "hot" point in the system such as the yellow/red wire after the fuse, or the yellow wire from the ammeter, to eliminate the usually troublesome main lighting switch.
Don Rogers | -- 07-05-2010 @ 2:59 PM |
Tom, There must be a difference with your repro harness. See pgs 152 thru 155 in 1935-36 Ford Book. Regards Don
trjford8 | -- 07-05-2010 @ 7:48 PM |
Don, thanks.
poss | -- 07-09-2010 @ 6:29 AM |
Thanks to all,I guess I will find out if they work.. Paul
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=1501 |
