pohair | -- 07-02-2010 @ 10:58 AM |
I am in the process of restoring a 38 standard 4 dr. When we started on rebuilding the 60hp flathead I noticed it had a lincoln/zephyr script carb with the numbers 06H. I thought the 60hp came with an 81 stromberg. Has anyone ever heard of this, and do you think it will run okay with this carb. Thanks Pat
37RAGTOPMAN | -- 07-03-2010 @ 6:45 AM |
Measure the carb stand ports on the intake manifold and then measure the carb throttle plate venturi,on the carburetor are they close.? if the carb venturi is much bigger, it is not the right one, hope this helps,37RAGTOPMAN KEEK OM TRUCKIN,,,,!!!!!!!!!
supereal | -- 07-03-2010 @ 8:26 AM |
The correct 60hp carb is the 922A. The carb is unique to the 60hp, and will not run correctly with any other due to the venturi size.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=1496 |
