38woody | -- 06-21-2021 @ 10:31 AM |
I came across a set of fog lights that I think would be a correct dealer option for my 1938 woody I was wondering if any one could confirm this for me before I try to purchase?
kubes40 | -- 06-21-2021 @ 11:04 AM |
Might you post a photo of the top of the bucket. On proper '38 road lamps, there should be the Ford script within a circle - stamped in that area. Above the circle "deluxe" is stamped in very small letters. "USA" is stamped just below the circle, again, in very small letters. Mike "Kube" Kubarth This message was edited by kubes40 on 6-21-21 @ 11:06 AM
38woody | -- 06-21-2021 @ 4:04 PM |
Unfortunately I don't have a picture of the top but I don't believe they are. I think they are just branded unity
40cpe | -- 06-21-2021 @ 5:13 PM |
I have a set on my '38 similar to those. No "Ford" logo, just Unity. They are the pre-sealed beam lights.
Dream38v8 | -- 06-22-2021 @ 5:44 AM |
38woody, my '38 has a set of Unity foglights. They were on the car when I purchased in '16 and when the former owner purchased the car in '02. Hence I am not sure of the origin. Dealer installed option? Aftermarket owner purchase? Whichever they really assist with night driving. They remind me of WWII blackout headlights. Ray
kubes40 | -- 06-22-2021 @ 6:00 AM |
Guys, 38woody was inquiring as to what is CORRECT for his '38. Neither of you (40coupe, dream38V8) have the correct lamps. And, it appears the lamps 38woody is contemplating the purchase of are not correct either. Ray, your road lamps are not even close to correct. Mike "Kube" Kubarth This message was edited by kubes40 on 6-22-21 @ 6:01 AM
38woody | -- 06-22-2021 @ 6:08 AM |
Yes I'm looking for what is correct I currently have sealed beam repops on the car but would love to find some originals that would of been an option from the dealer when bought new. Also you guys that do have them what do you do about the extra power demand my 3 brush generator will not keep up with the current lights the Amp needle drops way into the negative?
kubes40 | -- 06-22-2021 @ 6:14 AM |
The correct lamps are scarce. More rare in fact than the '40 style, which are themselves tough to find. Here's a the best photo I could find. This (one of two) I'd restored for a '39 convertible restoration I'd done a few years back. It (photo) should help a bit towards finding correct lamps. Mike "Kube" Kubarth This message was edited by kubes40 on 6-22-21 @ 6:35 AM
Dream38v8 | -- 06-22-2021 @ 8:22 AM |
Mike, I understand my foglights are not correct. All foglights I've seen have either a clear or amber lens. Mine are the only combo clear / amber pair I've seen. Ray
40 Coupe | -- 06-22-2021 @ 10:22 AM |
Some years ago Bob Drake reproduced the road light with the large oval and Ford script. Original lights have a square head set screw on the steel base. The set screw prevents the bolt holding the light to the mounting from coming loose. The reproductions do not have provision for the set screw. This message was edited by 40 Coupe on 6-22-21 @ 10:28 AM
kubes40 | -- 06-22-2021 @ 12:09 PM |
Ray, The lens can be correct. It's the lamps themselves that are incorrect. The lens you have amber / clear were export. I have a few. I think they are interesting. Mike "Kube" Kubarth
kubes40 | -- 06-22-2021 @ 12:10 PM |
The lamps Drake made years ago were perhaps arguably, one of the better things he'd produced. At first glance, one could easily mistake them for authentic lamps. Unfortunately, the lens were not the same diameter as the authentic counterparts. Mike "Kube" Kubarth
38woody | -- 06-22-2021 @ 3:41 PM |
Ok so I think I have located one now seeing pictures needs to be restored though
kubes40 | -- 06-22-2021 @ 3:49 PM |
That's the critter! Mike "Kube" Kubarth
38woody | -- 06-22-2021 @ 4:56 PM |
Awesome I would just have to find 1 more then restore them I feel like restoring them could get pricey
kubes40 | -- 06-22-2021 @ 6:18 PM |
I use the services of The Chrome Shop in Menasha, WI. Been using them for 35+ years. EXCEPTIONAL workmanship and ethical, honest man (Steve) that owns the place. One pair of lamps, about $750 to make them flawless. Worth every cent. Mike "Kube" Kubarth
38woody | -- 06-23-2021 @ 3:54 PM |
Thanks I appreciate all the help now I know I can spot the ones I need
38woody | -- 06-23-2021 @ 3:59 PM |
One more quick question would anyone have a picture of the correct switch that would of been installed?
kubes40 | -- 06-23-2021 @ 5:11 PM |
Ask and ye shall receive... Mike "Kube" Kubarth By the way, please open up your private message box so you may receive messages. Might prove to be helpful, hint, hint. This message was edited by kubes40 on 6-23-21 @ 5:12 PM
38woody | -- 06-23-2021 @ 6:23 PM |
That's completely different than I thought it would be I figured it would be one of the ones that hangs below the dash which is what I currently have. Does anyone reproduce these?
40 Coupe | -- 06-24-2021 @ 5:13 AM |
The switch is not reproduced. The knob color is not black (later style)
kubes40 | -- 06-24-2021 @ 5:37 AM |
38Woodie, ENABLE your private message mailbox! Mike "Kube" Kubarth
38woody | -- 06-24-2021 @ 4:47 PM |
I just enabled it didn't realize I had to turn messages on
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=14940 |
