JohnA | -- 06-07-2021 @ 4:44 PM |
I have a 1948 Ford 2dr with the 239 stock, it has a holly 94 model 59. When the engine is not running and I work the throttle, should their not be fuel squirting out of the spray tubes in carb. Replaced power valve today, doesn't like to start with choke???. Johna
carcrazy | -- 06-07-2021 @ 7:21 PM |
If there is fuel in the float bowl, fuel should be discharged from the accelerator pump nozzle jets when the throttle is moved from closed to open position.
supereal | -- 06-26-2021 @ 9:02 AM |
See my post above.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=14895 |
