daoust | -- 06-01-2021 @ 9:33 AM |
I have a 1947 Ford Super Deluxe. I am in need of a new 6 volt battery in the correct Ford script case. I believe my current one is simply an Optima battery in a reproduction case. Does any one still make these? Can the old case be re-used with a new Optima battery? Any information or direction greatly appreciated. Thank you. David Daoust Stratham, NH David Daoust
ford38v8 | -- 06-01-2021 @ 11:54 AM |
Use the old case with the new Optima. Alan
TomO | -- 06-02-2021 @ 5:39 PM |
Depending upon when your case was made, you might have to modify the internal support to allow the taller new Optima battery to fit. It is not a big deal to do this. Tom
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=14878 |
