40fordor | -- 06-29-2010 @ 4:25 AM |
What is the approximate max temperature of the exhaust manifold on an 85 HP V8 ?
supereal | -- 06-29-2010 @ 10:59 AM |
I don't recall ever having seen a figure. The manifold temperature varies directly with the load and the fuel mixture. Very lean can turn a manifold nearly red under some conditions.
37RAGTOPMAN | -- 06-29-2010 @ 3:13 PM |
I take it you are looking for a good exhaust paint or coating, EASTWOOD has a stainless steel coating,that works, but remember what ever you use, you will have to apply once in a while. they all change in time and use, Be sure to read directions, KEEP ON TRUCKIN 37RAGTOPMAN,,,,
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=1478 |
