Arden | -- 04-19-2021 @ 9:01 PM |
Wanting to find out if a 215/75r/15 with 6” wide rim will fit ok. Thanks for your help!
carcrazy | -- 04-19-2021 @ 9:40 PM |
Unless you do some clearancing of the rear wheel areas, the largest tires that will comfortably fit on the car are 205/75R15 on the stock 5" wide wheels. If you can be happy with blackwall tires, you can use Goodyear Assurance All-Season Radial Tubeless tires. They are great tires at a reasonable price that perform well, provide a great ride and good tread life.
Arden | -- 04-20-2021 @ 4:18 AM |
Thank you! Appreciate your help!
sarahcecelia | -- 04-21-2021 @ 6:38 AM |
Good Year also has a narrow white wall radial tire in that size.( a friend of mine has them on his car) Regards, Steve Lee
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=14756 |
