bgalla | -- 06-28-2010 @ 9:59 AM |
I have a 36 block with later year cast iron heads. The distributor that came with the it (but not on it) is a 40B. This ,I think, was used with aluminum heads. Are the two compatable? Thanks Bruce
supereal | -- 06-28-2010 @ 11:31 AM |
There is no difference in the distributors between iron and aluminum heads. The correct distributor for your '36 should be marked 40-12127 if it uses the 3 bolt coil, 68-12127 is it has the 2 bolt coil. The point sets for both are 18-12107.
bgalla | -- 06-28-2010 @ 1:39 PM |
thanks for the valued info Brude
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=1471 |
