dlpierson | -- 03-09-2021 @ 8:54 PM |
Any recommendations where to send a new 6 volt regulator for adjustment for proper battery charging. Nobody here in Tucson has a clue.
1931 Flamingo | -- 03-10-2021 @ 5:28 AM |
No offense, but in all of Houston there isn't an Auto Electrical shop?? When I had my gen checked they wanted the reg also and vice/versa. Good Luck. Paul in CT
37RAGTOPMAN | -- 03-10-2021 @ 9:43 AM |
hi dlpierson What year and model of auto ? very difficult to answer with not much info on what you are trying to accomplish are you sure it is not the GENERATOR, not charging, is this a New VOLTAGE REGULATOR ? it should have been set at the factory, if you install it, you have to polarize it to make it charge, ground the field wire for just a instant, you could call CERTIFIED AUTO ELECTRIC 440 439 1100 ask for Jeff or EARL they should be able to adjust it, if you send them the generator and regulator hope this helps 37Ragtopman
ford38v8 | -- 03-10-2021 @ 6:12 PM |
I'm no expert on the subject, but I'm told that for best results, adjustments to the regulator must be done under the anticipated operating conditions, meaning engine compartment temperature, condition of the generator, and electrical resistance of the wiring. Paul in CT, I guess he can just walk at a fast clip from Tuscon to Houston? ![]() Alan
dlpierson | -- 03-10-2021 @ 9:01 PM |
Stock‘50 Ford car. 6 volt Sorensen regular from eBay gets about 6.9 volts max (6.26 engine off) New NAPA and Mac’s show no voltage increase engine on Very old eBay regulator yields constant 8.5 volts C&G slight voltage gain Generator rebuilt last year. Cannot take regulator in for adjustment as they closed up shop Generator tested on car jumping armature to field with good voltage gain revving up engine. I have 2 meters that read the same. Maybe the Sorensen unit is ok?
40 Coupe | -- 03-11-2021 @ 4:49 AM |
The regulator (vehicle running) voltage level should be 7.2 to 7.5V make sure your analog only voltmeter is calibrated correctly
TomO | -- 03-11-2021 @ 7:44 AM |
The regulator should allow the generator to provide between 7.2 and 7.4 volts at 1,200 RPM. If yours is not doing that, check to make sure that the generator and regulator are both grounded, by connecting your voltmeter black lead to the generator through bolt and the red lead to the POS post (not the cable). Rev the engine to about 1,200 rpm and read the meter, It should be 0V. If it reads higher, check the grounding cable for corrosion and the generator mount for paint. Next leave the generator meter lead attached and move the red lead to the base of the regulator. Increase rpms to about 1,200 again and read the meter. It should read 0V. If it reads higher, clean the area under the mounting bolts for the regulator and the threaded holes in the firewall and then retest. You may have to add a toothed washer under the regulator mounts. Tucson Alternator may be able to check your regulator for you. https://www.tucsonalternator.com/ I don't know anything about the company, I just found them by doing a search. If you are willing to drive to Phoenix, Tony Serritella should be able to adjust your regulator for you. Give him a call first as he may be very busy. http://tonysrocketgarage.com/ Tom This message was edited by TomO on 3-11-21 @ 8:01 AM
1931 Flamingo | -- 03-11-2021 @ 8:08 AM |
FORD38V8 My mistake. I misread the post ! ! Paul in CT
dlpierson | -- 03-11-2021 @ 8:13 PM |
Thanks TomO, Will try the grounding tests tomorrow.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=14666 |
