dean333 | -- 03-08-2021 @ 6:15 PM |
I just acquired a 34 missing the battery. What are the dimensions of the battery I need? What spark plug type? Thanks, Tim TIM CARLIG
MG | -- 03-08-2021 @ 7:10 PM |
Group 2LF Battery > https://www.batterycentralmall.com/Batteries/TurboStart/Script/S2LF_L.html LENGTH 10-1/2" WIDTH 7" HEIGHT (TO TOP OF POSTS) 7-7/8"
dean333 | -- 03-08-2021 @ 8:04 PM |
Thanks! TIM CARLIG
carcrazy | -- 03-09-2021 @ 12:07 AM |
You can buy the correct type of spark plugs from Van Pelt, LLC at their website listed under links - friends on the left side of this page. They are 18mm thread spark plugs part number 40-12405M.
ken ct. | -- 03-09-2021 @ 3:57 AM |
Ive been using Champ "D-21 " for going on 30 yrs,work fine in a 36 coupe,same as a 34 engine. 18 mm plug,nice hot plug that burns away all fouling. Availible almost any local parts store. ken ct
3w2 | -- 03-09-2021 @ 5:08 AM |
In case you are curious, the original battery dimensions were: 7 1/4" x 10 9/16" x 7 1/8" (height) and the original spark plugs were Champion C-7 (early '34s) or Champion 7 (late '34s).
dean333 | -- 08-05-2021 @ 1:48 AM |
Well the 34 I originally asked about had a seized engine so I sold it. The “new” 34 I purchased has a 59AB engine. What spark plug and gap for it? Thanks! TIM CARLIG
51504bat | -- 08-05-2021 @ 6:38 AM |
Champion H-10 per my Motors Manual. Autolite 216's will work as well. I believe the recommended gap is .025 but I could be wrong. I'm sure someone else will provide the correct gap if I'm incorrect. ______________ No signature
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=14663 |
