bw3240 | -- 02-16-2021 @ 7:11 PM |
What voltage drop or resist0r can be used to safely power the original horns on my 39 after converting to 12 Volts? Part number, source? Thnks
TomO | -- 02-17-2021 @ 12:37 PM |
The horns will work on 12 volts and I do not recommend using a resister to drop the voltage due to the high current used by horns. If the horns draw 30 amps (typical), you would need a 0.2 ohm resister that could dissipate 180 watts of heat. Tom
51504bat | -- 02-17-2021 @ 12:40 PM |
I run the single 6 volt horn on my '39 p/u on 12 volts. Works fine. Maybe a little load but I don't use it much. But when a knuckle head pulls out or turns left in front of me it really gets their attention. ______________ No signature
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=14616 |
