leazer 48 | -- 02-08-2021 @ 3:36 PM |
I found the right heater hose support bracket for my 48 flathead, I know that is mounted on the right side of the engine, I just need the location information, is it mounted on a head stud or some other location on the engine?
42wagon | -- 02-09-2021 @ 3:44 AM |
Not sure what you have without a picture. On my 42 it is sort of a double clamp with one side clamping the hose and the other side clamping the hose to the steel tube conduit for the spark plug wires.
TomO | -- 02-09-2021 @ 8:53 AM |
From looking at cars for sale , it looks like it goes on the bottom head stud in the row just behind the no. 1 spark plug. https://classiccars.com/listings/view/1433479/1947-mercury-coupe-for-sale-in-san-jose-california-95129 I searched Mercury for sale as more of them had heaters. Tom
leazer 48 | -- 02-09-2021 @ 9:44 AM |
thanks for the post it did the trick, is it alright to remove stud nut to mount the bracket without re-torqueing all the head nuts?
TomO | -- 02-10-2021 @ 7:06 AM |
You should be able to remove and replace the nut on one stud without re-torquing the rest of the nuts. It is not a bad idea to check the torque for 55 Ft.lbs. on all of the nuts occasionally. Tom
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=14590 |
