oldfordman | -- 02-02-2021 @ 8:30 PM |
Hi all, Loooking for recommendations for windshield rubber seal. Who, in your expert opinions has the best one? As usual, thank you for your help. Don
kubes40 | -- 02-03-2021 @ 8:23 AM |
Drake Mike "Kube" Kubarth
oldfordman | -- 02-03-2021 @ 9:32 AM |
Thanks Kube Appreciate it!
RICKS2L | -- 02-03-2021 @ 11:20 AM |
I bought mine from C and G Ford in California. worked just fine
oldfordman | -- 02-03-2021 @ 2:35 PM |
Thank you
oldfordman | -- 02-06-2021 @ 12:01 PM |
Got my windshield rubber from Drake in two days, great service and the rubber looks really good! Now, to get it installed....does anyone have words of wisdom before I mess up! Thanks Don
kubes40 | -- 02-06-2021 @ 12:15 PM |
Words of wisdom? * Be patient, be very patient. * I believe it goes without saying but just in case... the windshield must be removed from the car. I would not dare attempt to tackle this task any other way. * Be certain ALL traces of old gasket are removed. Don't cheat... ALL of the old gasket has to be out of there! * Install the four corners first. Then install the horizontal sides and finally the vertical sides. * Don't skimp on the lubricant. I prefer (spray) glass cleaner as it will dry up. Soaps will come back to haunt you in the form of bubbles when you wash the car. Do NOT use any type of silicone lubricant and do NOT use any type of sealer. Mike "Kube" Kubarth
40cpe | -- 02-06-2021 @ 3:09 PM |
The cleanliness of the channel can't be over-emphasized.
51504bat | -- 02-07-2021 @ 6:49 AM |
Per the guy who sold me the windshield for my '39 p/u, glass cleaner only for lubricant. NEVER WD 40. He knew his stuff when it came to old car glass so that was good enough for me. ______________ No signature
Mr Rogers | -- 02-07-2021 @ 1:09 PM |
Use painter's type masking tape to hold in place during install.
oldfordman | -- 02-26-2021 @ 12:20 PM |
Thanks for all the good info. The windshield is out and the rubber is in! Good fit. Now, reinstalling the windshield, it doesn’t seat good. New rubber?? Will it eventually “settle” in?
kubes40 | -- 02-26-2021 @ 4:34 PM |
It will settle in if you were super careful getting it seated in the channel fully and properly. Park it outside in the sun. That will help. Mike "Kube" Kubarth
oldfordman | -- 02-26-2021 @ 5:37 PM |
Thanks Kube, I will do that. Thanks to all
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=14571 |
