jcf | -- 01-20-2021 @ 2:06 PM |
I have replaced the top material, that is, it is tacked in place, with the padding and liner that came with the kit. Now I'm trying to install the original steel moldings around the top material, however, when I removed them from the car, I might have distorted their shape beyond my ability to put them back in original shape. So my question is, does anyone have experience installing the aluminum moldings that the antique parts outfits now sell? They are sold in straight pieces, so it will be up to me to bend the 4 round corners, so I wonder how I do that. Thanks for any advice you can give me. John thanks, John Fisher
40 Coupe | -- 01-21-2021 @ 5:26 AM |
It is nearly impossible to do a 90 degree bend in the aluminum reproduction trim. There was a fellow in CA that developed tools for his purpose and would bend the aluminum trim. Not cheep! Suggest you be very careful with the steel trim and have it repaired, if possible. Mitch*ll Fab. & Machine Mark Mitch*ll 850 E. 5th St. Oxnard, CA 93030 310 849-7963 marksshop@la.twcbc.com This message was edited by 40 Coupe on 1-21-21 @ 5:30 AM
jcf | -- 01-21-2021 @ 10:58 AM |
Thanks for your reply. I definitely don't need more expensive tools! So, I'll be patient and restore the steel pieces. Thanks. John thanks, John Fisher
jcf | -- 01-29-2021 @ 9:48 AM |
I am back to using the original steel moldings, I pretty much have them back in decent shape. Now i realize the tacks the supplier sent with the top material are too big, that is, the head is too large to go thru the grove in the moldings. I have gone to a couple hardware stores, no luck so far. I wonder if Ford originally used a special nail in those steel moldings. Without a photo, I also wonder if any reader knows what I'm talking about. thanks, John Fisher
trjford8 | -- 01-31-2021 @ 8:08 AM |
In the past I have used small nails that have a smaller head that worked fine. Check your local hardware store. The grove in the trim is sealed with a small rubber seal similar to the round rubber used to replace screening on house screens. This message was edited by trjford8 on 1-31-21 @ 8:11 AM
TomO | -- 01-31-2021 @ 8:29 AM |
Try asking for "brads" in the hardware store. They have a smaller head than tacks and come in lengths similar to tacks. Tom
3w2 | -- 01-31-2021 @ 2:24 PM |
I use #3 Robertson flat head screws to attach the moldings to avoid nicking the finish paint on the moldings as we paint them before installation to ensure better coverage.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=14522 |
