bosborn | -- 01-20-2021 @ 6:03 AM |
Planning to purchase replacement bearing set-up from Skip. While searching, I stumbled on this: https://www.smallfordspares.co.uk/products/e93a-4658-a-bearing-prop. Just fyi and wondering if this might fit our vehicles.
bosborn | -- 01-20-2021 @ 6:09 AM |
Sorry - looks like the link doesn't go directly to the part. I think you can type the PN (93A-4648-A) in the Part Search box to get to the item.
37RAGTOPMAN | -- 02-04-2021 @ 10:34 AM |
torque tube bearing, What I found out that if the torque tube has NO grease fitting it has the large hollow tube drive shaft if it has the grease fitting it has the center bearing, it varies though the years, just a little added information, 37Ragtopman
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=14520 |
