jamesmundstock | -- 01-16-2021 @ 5:51 PM |
I installed electric wipers and a converted radio. I want to power both after the ignition switch is turned on. Which contact is better; the coil side or the gauge side or does it matter? Thanks in advance for the responses.
jims33 | -- 01-17-2021 @ 2:11 PM |
If what you mean is that you want to power the wipers and radio through a stock ignition switch, that isn't a real good idea. Those switches can handle the current they were designed for and not much more. A separate switch or using the ignition switch to power a relay would be better.
alanwoodieman | -- 01-17-2021 @ 2:39 PM |
never the coil side. I take it you have converted to 12 volt? if so the idea of a relay to turn on a fuse board is a good one, just used the gauge post for this
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=14512 |
