dso72 | -- 06-24-2010 @ 10:43 AM |
I'm looking at a transmission for my 35. I found a transmission that the owner claims to be a 1935 but some of the numbers do not match the early v8 book. Can anyone help me identify this transmission. Here are the numbers: case 18-7006,v8 book 18-7005; gear shift housing 40-7222, v8 book 40-7204. There are no grease fittings on the clutch release shaft and it has a S shaped gear shift lever. Another oddity is the vin #. It starts with an 18 but the production number is too low. The number starts in the eight hundred thousand not one million eight hundred thousand. The inspection cover has a hole but no grease cup and a greaseless clutch release bearing. Thanks for helping me decode this transmission.
42wagon | -- 06-24-2010 @ 3:33 PM |
I'm sure that all the features you describe would clinch it but to me the serial number is the key. *18-800000* is a number midway in the 1934 production run. Therefore I would say you have a 1934 transmission.
dso72 | -- 06-24-2010 @ 4:45 PM |
Thanks 42wagon. That clarifies a lot.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=1448 |
