camsaure | -- 12-22-2020 @ 10:34 PM |
I am in need of the passenger side quarter window seal. Bob Drake had them listed but surprise, they are out of stock. Anybody have an extra laying around or know of a vendor who may still have them on hand? Thanks, Cam
1931 Flamingo | -- 12-23-2020 @ 5:51 AM |
Maybe try C&G or Joe's?? Paul in CT
Barney | -- 12-23-2020 @ 9:36 AM |
Cam, If I remember correctly, the quarter window and rear window seals are the same, except for the length. I resorted to buying rear window seals and butting two pieces together to make one, longer quarter seal. Yes, there'll be two butt splices, but if you take your time they're not 'eye-catchers' and nobody will know except you and me . Barney
Barney | -- 12-23-2020 @ 9:38 AM |
Cam, Oooops, just noticed yours is a '36; mine is a '40. They may be difference; don't know. Beware. Barney
alanwoodieman | -- 12-23-2020 @ 9:49 AM |
they were out of stock when I worked on a 36 4 years ago!! I used a 46/48 and trimmed them down to fit, the pivot points locations are the same so had to cut down and super glue the long length to fit the glass
trjford8 | -- 12-23-2020 @ 11:26 AM |
Might also try Metro Molded Products in Minnesota or Dennis Carpenter. This message was edited by trjford8 on 12-23-20 @ 11:26 AM
camsaure | -- 12-23-2020 @ 8:41 PM |
Thanks everyone, I thought that I was going to have to modify a later one (good idea), but then found them at Metro. Not cheap, but then what is?
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=14439 |
