RockyWatts | -- 12-12-2020 @ 12:52 PM |
VIN does not have the 18 - in front of number or the star Is this common?
nelsb01 | -- 12-12-2020 @ 1:00 PM |
Have you removed enough paint from the frame rail? Looks lkie there is a STAR after the last number, so the STAR and 18 - could be farther to the left. This was all done by hand, so there can be some space between numbers. Also, dont get too carried away with a grinder as the numbers sometimes are very weakly stamped to begin with and you could accidently remove them. Light sandpaper is recommended. This message was edited by nelsb01 on 12-12-20 @ 1:03 PM
RockyWatts | -- 12-12-2020 @ 1:10 PM |
Thanks Uncovered star nothing else. Read in restoration manual that the 18- was sometimes ommitted
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=14401 |
