bill41ford | -- 12-05-2020 @ 6:19 AM |
Took springs apart to clean and lube - looked to renew spring clamps (one was broken) but only see 33-34 ford clamps available from common sources - anyone know if they will fit or where I can find some to fit?
kubes40 | -- 12-05-2020 @ 8:01 AM |
Are you referring to the small clamps that hold the spring together? Mike "Kube" Kubarth
bill41ford | -- 12-05-2020 @ 8:09 AM |
yes - u shaped clamps with bolts - riveted on spring
kubes40 | -- 12-05-2020 @ 10:54 AM |
Can you supply dimensions? The spring is 2" wide as I recall. Need to know the dimension from the center of the thru hole to the horizontal part of the clamp. Mike "Kube" Kubarth
ken ct. | -- 12-05-2020 @ 11:12 AM |
Try a spring place !! ken ct.
37RAGTOPMAN | -- 12-06-2020 @ 7:09 AM |
41 spring clamps you could try SOUTHSIDE OBSOLETE in MINN, Fred has many NOS parts, even NEW OLD STOCK FORD FRONT SPRINGS, EXACTLY like the one you are trying to clean, just remember it is 80 years old, maybe a little tired my 2 cents 37Rgtopman
bill41ford | -- 12-07-2020 @ 1:27 PM |
Just got an nos 41 front axle from Fred... I will email him -- dimensions of clamp are 2 4/64 inside --2 15/64 from end of vertical side to top of horizontal -- 1/4 hole for bolt -- 1 52/64 center of bolt hole to top of horizontal
kubes40 | -- 12-07-2020 @ 2:11 PM |
Bill, If Fred doesn't have them, let me know and I'll look. Mike "Kube" Kubarth
bill41ford | -- 12-07-2020 @ 7:38 PM |
Thanks , I'll check my home email to see if Fred got back to me.
bill41ford | -- 12-12-2020 @ 11:51 AM |
Fred came through again - thanks.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=14382 |
