eli33 | -- 12-04-2020 @ 9:33 AM |
Anyone out there have a solid head for my '35?
kubes40 | -- 12-04-2020 @ 9:35 AM |
Cast iron heads are readily available and cheap. Check eBay, etc. Correct aluminum heads are scarce and pricey. You may also want to list this under "parts wanted" for a better response. I'm fairly certain that's what that column is for... Mike "Kube" Kubarth
kirkstad | -- 12-04-2020 @ 12:32 PM |
I have a cast Iron head from a 36 for dome type pistons but I can't remember which side, I'll dig it out if you think that will help, if so, you can have it. Frank
eli33 | -- 12-04-2020 @ 3:30 PM |
Thanks but mine are flat.
kubes40 | -- 12-04-2020 @ 3:51 PM |
cast or aluminum? Mike "Kube" Kubarth
Sneezer | -- 12-05-2020 @ 3:45 AM |
I have both side for flat pistons. $25 plus shipping for one. PM if your interested. Arnie
eli33 | -- 12-05-2020 @ 5:02 AM |
Aluminum
Sneezer | -- 12-05-2020 @ 5:04 PM |
Unable to open your PM's. My heads are cast iron so of no use to you
eli33 | -- 12-05-2020 @ 6:04 PM |
Ok. Thanks for trying.
mfirth | -- 12-06-2020 @ 5:16 AM |
eli, you may want to try posting on "The Ford Barn" too. Good luck ! mike
37RAGTOPMAN | -- 12-06-2020 @ 6:55 AM |
eli33 You should use the part number on the head you are looking for to make life easier and to make sure you get the exact one you need, and are you sure it is a 1935 head to start with, ? FORD SCRIPT. and not a after market head, hope this helps 37Ragtopman
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=14380 |
