flatfoot | -- 11-30-2020 @ 8:45 AM |
I need an idea of how to secure my dash light switch to the dash. My anchor broke trying to install it. Anybody got any ideas? I saw a switch for sale for $200, but that is out of reason and question. It is a squeeze it together to remove from the dash. The vehicle is a '36 Ford 4dr Touring Sedan. It is stock. This message was edited by flatfoot on 11-30-20 @ 6:26 PM
MG | -- 11-30-2020 @ 10:37 AM |
What year car/truck?
flatfoot | -- 11-30-2020 @ 6:25 PM |
Oops. '36 Ford 4dr touring sedan.
camsaure | -- 12-01-2020 @ 11:19 AM |
crude, but how about a narrow hose clamp?
flatfoot | -- 12-01-2020 @ 2:14 PM |
It is the inside of the dash that holds the switch. The holder fits over the switch and it is spring steel, so when you want to remove it you squeeze the holders on either side towards the switch and it comes out towards you. So, I do not think a hose clamp will solve the problem I have.
TomO | -- 12-02-2020 @ 8:33 AM |
Try Restoration Specialties for something that you could use to replace the broken clips. https://www.restorationspecialties.com/Online-Shopping_ep_41.html Concourse parts has clips that are used to hold power window switches in the door panels. They may work for you, if they are not too wide. https://www.parts123.com/parts123/yb.dll?parta~dyndetail~Z5Z5Z50000051e~Z5Z5Z516055~P2.55~~~~S5WZ1EHQ1V17431616080m~Z5Z5Z5~Z5Z5Z50000051e Tom
Mr Rogers | -- 12-02-2020 @ 10:12 AM |
A picture is worth a thousand words .....
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=14366 |
